Home » Sponsored » Pi Speakers » 12Pi v2
Re: 12Pi v2 [message #51835 is a reply to message #51834] Mon, 18 February 2008 11:40 Go to previous messageGo to previous message
Are you sure you're not looking at the v1 drawings? We used to make the top bevel shorter than the bottom one, and it was 38-7/32" from the front. But the v2 drawing has both bevels cut the same, 36-3/8" from the front on each one. The dimension is only shown along the top edge, but you can see that it lines up with the bottom. This is a non-critical feature and you could use either style, but the new one has bevels cut the same on top and bottom.
Previous Topic: 3Pi Sensitivity
Next Topic: Mounting Eminence Driver
Current Time: Tue Nov 03 04:19:30 CST 2026
