Home » Sponsored » Pi Speakers » 12Pi dado dept
12Pi dado dept [message #51789] Sat, 02 February 2008 03:58 Go to next message
Roland Gama is currently offline  Roland Gama
Hello Wayne,
The diagram and the web link says that the depth of the dado on the access panel should be 7/16 of an inch as the the aluminum disc is 1/4 inch thickness.
Do you actually mean 5/16 inch depth of dado to make up for 1/16 inch gasket thickness???
Waiting for your help before I go with the router.
Thanks: Roland.
Re: 12Pi dado dept [message #51791 is a reply to message #51789] Sat, 02 February 2008 10:43 Go to previous messageGo to next message
The depth of the dado for the access panel is actually one of the few cuts that isn't all that critical. The proto and first models were all 5/16" deep. This makes the access panel flush with the side when the gasket is 1/16th", just like you said. But a deeper dado lets the panels be slightly recessed, and that works better when stacking horns on their sides.
Re: 12Pi dado dept [message #51793 is a reply to message #51791] Sat, 02 February 2008 21:45 Go to previous message
Thanks!!!
Previous Topic: Sub for Heresy's
Next Topic: Web site disapears?
Current Time: Mon Nov 02 03:53:10 CST 2026
