Home » Sponsored » Pi Speakers » Three pi sub
Three pi sub [message #51759] Thu, 24 January 2008 06:51 Go to next message
Roland Gama is currently offline  Roland Gama
Hello Wayne
Can I have the plans for the three pi sub? The ones using the lab12 drivers.
You've got mail! [message #51762 is a reply to message #51759] Thu, 24 January 2008 09:39 Go to previous messageGo to next message
Re: You've got mail! [message #51765 is a reply to message #51762] Fri, 25 January 2008 04:27 Go to previous messageGo to next message
Thanks for the plans.
How would you compare a pair of three pi subs against a single 12pi v2 in relation to sound quality not power?
Differences between subs [message #51766 is a reply to message #51765] Fri, 25 January 2008 09:34 Go to previous message
There are some basic differences between the two subs. The three π sub is a direct radiating reflex cabinet with Helmholtz frequency of 20Hz. The 12π hornsub is a push-pull folded horn with 1/4λ path length frequency of 30Hz.
The LAB12 woofer is a good driver, but its motor is a fairly common ferrite structure without a shorting ring. In the three π cabinet, excursion is lowest when the sub is used above 20Hz. Below that frequency, excursion and distortion rise rapidly.
The 12π basshorn subwoofer has three mechanisms that reduce distortion. One is push-pull drive, which works at all frequencies in the passband, but only reduces even numbered harmonics. The second mechanism is horn loading, which reduces excursion in the passband (above 30Hz), which in turn reduces distortion above 30Hz. The third thing is the front chamber and horn folds provide a low-pass filter that attenuates high frequencies, and that results in a reduction of harmonics from third on up.
The difference in output is about 15dB too. While that's not an indicator of quality all by itself, the fact remains that you need about 50x the power for the three π to equal the output of the 12π. So the 12π is loafing where the three π might be nearing its limits.
The three π is tuned lower, so that's the one area where it will perform better. You'll get flat response down to 20Hz. It is also a much smaller box.
Previous Topic: alpha 10 /psd2002?
Next Topic: 12Piv2 plans
Current Time: Mon Nov 02 09:40:10 CST 2026
