Home » Sponsored » Pi Speakers » Pi 7 crossover
Pi 7 crossover [message #51709] Fri, 11 January 2008 23:47 Go to next message
SamL is currently offline  SamL
Hi Wayne,
Is Pi7 crossover using the same Pseudo First-Order filter on JBL 2226 like Pi4? What is the crossover point for the 3 way?
Also, can I do a direct replacement on the tweeter with B&C DE250. I saw a few post over here about DE250 but not much been said about crossover.
Thanks,
Sam
You've got mail! [message #51710 is a reply to message #51709] Sat, 12 January 2008 10:25 Go to previous messageGo to next message
I've sent you plans for the seven π speaker, which includes the schematic for the crossover. The only change for use with the B&C DE250 compression driver is R1 should be 25Ω instead of 16Ω.
Very kind of you, thanks :D [message #51711 is a reply to message #51710] Sat, 12 January 2008 14:09 Go to previous messageGo to next message
Will read up your plan to see if this is what I am after.
Sam
Re: xover question [message #51726 is a reply to message #51710] Tue, 15 January 2008 11:36 Go to previous messageGo to next message
Wayne, I substituted the B&C DE250 w/out changing anything in the tweeter section of the xover, originally in Stage 4's. The woofers are now 2226's, w/ only the .7mH coil in series. I'm very happy with the sound (understatment) but was wondering if you'd recommend changing the R1 to a 25 ohm in this setup as well?
Re: xover answer [message #51729 is a reply to message #51726] Tue, 15 January 2008 12:54 Go to previous message
The DE250 works very well as a drop-in replacement for the PSD2002. It is slightly smoother above 8kHz. Impedance and sensitivity are slightly different, but not so much to make them incompatible with one another. That makes the DE250 work pretty well without any crossover changes.
The DE250 is slightly louder than the PSD2002 with the same input voltage though. Not much, just a smidge, about 1.5dB. That's not much, but if you want to attenuate it to match, substituting a 25Ω resistor for R1 instead of a 16Ω resistor brings it down by that amount.
As you know, I developed this crossover using Spice. The drivers were modeled using voice coil inductance and resistance, and parallel tank circuits were used to model resonances in the woofer/box and in the horn flare. It's a very good model.
However, I've recently been playing around with Keith Larson's Speaker Tester system. He has made an extension to Spice that allows measured driver impedance to be used. This makes the model even better because it uses actual impedance, even where nonlinearities change it from what an LRC model could describe.
I was able to bring the π crossover models straight across into the Smith & Larson system. The only modifications I had to make to the models were to include the impedance ZMA files for the drivers and to remove whitespace, leaving just one space between component designator and node. So I could easily build off what I had with the Smith & Larson system, making it another step up the ladder, so to speak.
I was happy that the system pretty much just confirmed the original (pure) Spice models. As they are, they're very, very good. But with the improved visibility this system gives me, I can probably optimize the circuit even further. For one thing, I found that the 8.0uF capacitor can be slightly decreased to 6.8uF or 7.5uF. There's some wiggle room in that component which is good because 6.8uF is a more common value. We want some peaking there, but we could use a little bit less, so the smaller value is fine.
Another part of what prompted me to do this is I get tired of making all those cable assemblies and wanted to etch circuit boards that included them. So I've had a couple hundred boards made that have room for a lot more components, allowing me to put everything on the board instead of having R1, R2 and C1 in the cable assembly. That will be a welcome change too. In a couple of months, we'll have new crossover boards available and there may be some minor changes in component values as well.
Previous Topic: Impedance rise in hons
Next Topic: Stand for Theater 4?
Current Time: Thu Nov 19 07:19:59 CST 2026
