Home » Sponsored » Pi Speakers » Midhorns to load down to 200 Hz?
Midhorns to load down to 200 Hz? [message #51658] Fri, 28 December 2007 06:56 Go to next message
Peter Krojgaard is currently offline  Peter Krojgaard
Hi Wayne,
I have large, straight 29 Hz basshorns (see link below) and currently use a pair of BMS 4592 ND drivers in Jabo KH-50 horns from 320 Hz and up (these are not displayed in the pics though). However, I am not satisfied with the BMS drivers that I find somewhat hard and sterile sounding. Therefore, I consider trying hornloaded cone mids and a tweeter above instead. This is where your midhorn(s) come in!
I would really like to get the midhorn to go down to 200 Hz, since my basshorns sounds best below 200 Hz. But since the midhorns will be positioned on top of my basshorns (app. where the wooden Bentwood midhorn are located in the picture), they will not be corner loaded as in the 7Pi application and the standard 7PI midhorn will probably not load down to 200 Hz in this position….
My question is:
Could I somehow extend or enlarge the 7Pi midhorns, so they would cover the 200-1000 Hz range when mounted on top of my bass horns? (I have also considered your 9Pi midhorns, but their 40x40 coverage may be difficult to mate with a 90x40 tweeter horn, or….). I have modelled a 90 degree conical horn in HornResp (throat=130 cm2; Mouth=3600 cm2 [35” w x 16” h]; Length=20”) – would this be a sensible approach???
I already have a pair of 10” PD.107 drivers – quite simular to the JBL 2012 -- that I would like to try.
I thank you a lot in advance!
Kind regards
Peter
Re: Midhorns to load down to 200 Hz? [message #51659 is a reply to message #51658] Fri, 28 December 2007 09:39 Go to previous messageGo to next message
Corner loaded, the seven π midhorn is good down to 150Hz. As radiating angle is made larger, low end response suffers. But I see from your photos that your horns are positioned near boundaries and the room is not very large. You may find the boundary reinforcement you have is enough. If not, I'd try a few alternatives in Hornresp and see what you come up with. The description you've given modeled pretty well.
Re: Midhorns to load down to 200 Hz? [message #51660 is a reply to message #51659] Sat, 29 December 2007 04:07 Go to previous messageGo to next message
Hi Wayne,
Thanks a lot for your reply! Immediately, I think I will be most inclined to try the large horn then. However, a 35" wide horn is huge and I may consider a narrower 60 x 40 design. In that case, I will have to look for a 60 x 40 tweeter. Can you recommend any 60 x 40 horns for 1" drivers?
Thanks a gain!
Kind regrads
Peter
Re: Midhorns to load down to 200 Hz? [message #51661 is a reply to message #51660] Sat, 29 December 2007 09:12 Go to previous messageGo to next message
Three feet wide, huh? That's big, but not compared to your basshorns.
Re: Midhorns to load down to 200 Hz? [message #51662 is a reply to message #51661] Sat, 29 December 2007 10:08 Go to previous messageGo to next message
Yes, I know the bass horns are huge. I asure you that they have punch in spades:-)
Thanks a lot for your help, Wayne!
Kind regards
Peter
Re: Midhorns to load down to 200 Hz? [message #51732 is a reply to message #51661] Tue, 15 January 2008 20:23 Go to previous messageGo to next message
Wayne,
Are your mid-horns really 35" wide? No wonder the pictures have
a low WAF. If not, what are the dimentions?
Chris
Re: Midhorns to load down to 200 Hz? [message #51738 is a reply to message #51732] Wed, 16 January 2008 12:51 Go to previous message
It's big but not quite that big. Mouth dimensions are 12" x 24", with a couple inches around that for the cabinet.
Previous Topic: Stand for Theater 4?
Next Topic: Quarter wave ported box?
Current Time: Tue Nov 03 06:05:12 CST 2026
