Home » Sponsored » Pi Speakers » Pi mid horn vs. Klipsch Lascala
Pi mid horn vs. Klipsch Lascala [message #51604] Thu, 13 December 2007 19:45 Go to next message
boblaz is currently offline  boblaz
Would there be any advantage to replacing the Lascala mid horn with the Pi midhorn?
Thanks
Re: Pi mid horn vs. Klipsch Lascala [message #51605 is a reply to message #51604] Thu, 13 December 2007 23:21 Go to previous messageGo to next message
The π midhorn runs deeper so you can lower your crossover frequency and get the midrange out of your basshorn.
Re: Pi mid horn vs. Klipsch Lascala [message #51606 is a reply to message #51605] Fri, 14 December 2007 17:18 Go to previous messageGo to next message
Thanks!!!
Re: Pi mid horn vs. Klipsch Lascala [message #51607 is a reply to message #51605] Sat, 15 December 2007 18:30 Go to previous messageGo to next message
Wayne,
What is included in the 10" wood midrange kit. How much is the horn flat pack + 10" eminence driver. Actually what I want is the cost of a kit with the 10" horn midbass, high frequency compression tweeter, plus crossover for this setup. I want to integrate this with the Lascala bass horn.
Thanks
Robert
Re: Pi mid horn vs. Klipsch Lascala [message #51609 is a reply to message #51607] Sun, 16 December 2007 09:28 Go to previous message
The midhorn flatpack kit includes the four flare sides and the throat plate plus Miller dowels for easy assembly. You don't need clamps with this setup because the Miller dowels hold everything in place.
Cost depends on the wood chosen. A kit like you're talking about would be about $350-400, depending on the wood you pick.
Previous Topic: Theater 4 and 7 plans
Next Topic: nearly ready for Pi speakers in the UK!
Current Time: Wed Nov 04 21:59:41 CST 2026
