Home » Sponsored » Pi Speakers » Pro 7
Pro 7 [message #51568] Wed, 28 November 2007 05:53 Go to next message
Zene Gillette is currently offline  Zene Gillette
Wayne ... I am using P.audio P150 (JBL 2226 clone) in backloaded JBL Model 34 bass horns. They couldn't produce bass with a stiff wind. I would like to use the Model 34's for UB and the P150's in your Pro 7's. Assuming they will perform close to the JBL's, what is the bass extension I might get from them? Your Boxplot doesn't take into consideration corner placement if I read right. They will be driven by two 375 watt plate amps (OAudio) that has built in EQ so I can tweak if necessary.
Plan is to use them for subwoofers only up to 60hz-80hz. If good idea will you send plans. I will certainly accept alternative ideas. Just for reference what will stacked Pro 7's do?
The JBL Model 34 horns originally used JBL D130's. Can you recommend a driver that might work well considering they only need to go to 50hz or so?
Can I get your mid and tweeter horns separate?
Thanks, Zene
Re: Pro 7 [message #51570 is a reply to message #51568] Thu, 29 November 2007 14:19 Go to previous messageGo to next message
The midhorns are avilable as a flat pack kit, or you can build them yourself from the plans. The wooden tweeter horn is available separately, or you can use an Eminence H290.
As for the seven π bass bin, it is slightly overdamped which works well for corner loading. You'll definitely get some room gain, so you don't want to overdo it by having an alignment like B4. With the 2226 in a seven π bass bin, you can expect nice clean bass down to 40Hz, with gradual rolloff below that.
Re: Pro 7 [message #51571 is a reply to message #51570] Thu, 29 November 2007 15:00 Go to previous messageGo to next message
Thanks, will you pop over plans for the Pro7 15 so I can see if will fit.
Zene
Re: Pro 7 [message #51572 is a reply to message #51571] Thu, 29 November 2007 15:15 Go to previous messageGo to next message
Certainly. Please send me your E-Mail address and I'll send the plans right over.
Re: Pro 7 [message #51573 is a reply to message #51572] Thu, 29 November 2007 15:21 Go to previous messageGo to next message
Wayne ... I knew I forgot something. Da!
zene@comcast.net
Re: Pro 7 [message #51574 is a reply to message #51573] Thu, 29 November 2007 15:50 Go to previous messageGo to next message
Wayne, can I trouble you for the mid plans, also?
And, do I really need back wings if I use as subwoofer and cross low (
You've got mail! [message #51575 is a reply to message #51574] Thu, 29 November 2007 20:34 Go to previous messageGo to next message
Midhorn plans are included. The angled panels in the back are really there for structural support, with the shape of the rear area being used as a positioning device to fit properly into the corner.
Re: You've got mail! [message #51576 is a reply to message #51575] Thu, 29 November 2007 21:43 Go to previous message
Appreciate your efforts for us acoustically challenged. Think I used that line before.
Zene
Previous Topic: Imaging with Pi Speakers
Next Topic: matching a Table Tuba bass horn
Current Time: Sat Oct 24 23:55:38 CDT 2026
