Home » Sponsored » Pi Speakers » To Mr FredT
To Mr FredT [message #51550] Wed, 14 November 2007 07:42 Go to next message
j.luis is currently offline  j.luis
Hy ..I recently got a eminence Alpha 8 drivers spec y would like to get your info to make a One Pi tower ..Your info will be highly appreciated . Thanks
Re: To Mr FredT [message #51552 is a reply to message #51550] Fri, 16 November 2007 18:13 Go to previous messageGo to next message
There are two versions of the One Pi Tower, the very easy version and the easy version. Here's the link to the very easy version step-by-step building instructions. This version is intended for people who don't have access to a table saw or a router. It uses pre cut 12" mdf boards (they're really 11-1/4"). The other version has more appealing dimensions because its depth is greater than its width. I have a pair upstairs somewhere and will measure them and post the dimensions.
Re: To Mr FredT [message #51553 is a reply to message #51552] Sat, 17 November 2007 09:11 Go to previous messageGo to next message
Hey FredT. * Thanks & admiration *
Pi One Towers here [message #51554 is a reply to message #51550] Sat, 17 November 2007 12:58 Go to previous message
JammyDodger is currently offline  JammyDodger
You might like to have a look at the Pi One Towers here:
http://www.iol.ie/~waltonaudio/pione.html
Previous Topic: jbl 2447
Next Topic: Delta 10_A speakers
Current Time: Thu Nov 12 09:59:10 CST 2026
