Home » Sponsored » Pi Speakers » Replacement For Fiberglass in 2Pi
Replacement For Fiberglass in 2Pi [message #51525] Tue, 30 October 2007 19:57 Go to next message
Beltway Bandit is currently offline  Beltway Bandit
Is it a 1 for 1 swap between the 1 inch of fiberglass as specified in the 2pi directions and 1 inch of polyester batting? Would an open cell acoustic foam that PE sells work too?
Re: Replacement For Fiberglass in 2Pi [message #51527 is a reply to message #51525] Tue, 30 October 2007 22:11 Go to previous messageGo to next message
If the cells are large enough, open cell foam is much more acoustically transparent than fiberglass insulation. It's what some use for speaker grilles. I think probably the small cell stuff is more absorbent, but I haven't made any measurements to see.
Re: Replacement For Fiberglass in 2Pi [message #51529 is a reply to message #51525] Tue, 30 October 2007 22:23 Go to previous message
I just used the fiberglass "full strength". They sound good to me.
Previous Topic: Studio Two Pi
Next Topic: Studio Two construction pics?
Current Time: Thu Nov 26 18:04:51 CST 2026
