Theater Seven Pi Question. [message #51512] |
Sun, 28 October 2007 15:25 ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Ed White
Messages: 34 Registered: May 2009
Baron |
This is just a suppose, thinking out loud question. If a person's Theater Seven Pi's were, well, in the corners of the listening area, but 15 feet apart, and the listing spot was not perfectly optimal...say in a square room. Mine is square. Would it be possible or at all advisable to have the midhorn/tweeter setup on separate stands inside the bass units...say 8 feet apart? The bass units being in the corners of a 15 ft wide room and the mid tweets being located between them on stands at listening. Will that mess up imaging?
Re: Theater Seven Pi Question. [message #51518 is a reply to message #51514] |
Mon, 29 October 2007 12:22 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Ed White
Baron |
Aha. I'm making the midhorn/tweeter as a one piece removable unit, and was trying to understand the placement envelope of these as it's design parameters allows. God knows this thing would be a beast if were all built into one cabinet. You'd need two men and a truck to move it. It was just a thought. Has anybody ever done a center channel with these guys...kinda like the old Klipsch method? The Sevens in the corners and maybe a 4 pi in the center with the old school center channel wiring setup? Building stuff tends to put you into a sorta mad scientist mode, I'm afraid. It's fun to play with ideas, though.
Re: Theater Seven Pi Question. [message #51519 is a reply to message #51518] |
Mon, 29 October 2007 15:26 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) |
Messages: 18748 Registered: January 2001
You're right, making them as a single unit would be a bear. We build them as three pieces and pin them together:For center channel and surrounds, I'd use three π's or four π's of the same line. Surrounds could be one π's or two π's.
