Home » Sponsored » Pi Speakers » Hornresp - New Website Address
Hornresp - New Website Address [message #51495] Thu, 25 October 2007 01:39 Go to next message
David McBean is currently offline  David McBean
Hi Wayne,
Just letting you know that for reasons beyond my control, my website address has been changed to:
http://www.dmcbean.bigblog.com.au
Also, Hornresp can now model axisymmetric Le Cléac'h flare horns - Version 17.00 refers. The expansion profile is generated using the new improved method documented in Jean-Michel's 2007 spreadsheet. I have assumed a plane wavefront at the throat.
Simply press L when the horn segment 1 length parameter has the focus to select "Lec" for Le Cléac'h flare.
Kind regards,
David
Re: Hornresp - New Website Address [message #51496 is a reply to message #51495] Thu, 25 October 2007 08:22 Go to previous messageGo to next message
Thanks for posting here. I'll be sure to reference the new address from now on.
By the way, I want to thank you personally for developing and supporting this program. I've grown to depend on it heavily for the last 8 years or so. Many times, I make a Hornresp model and then use LMS to measure a prototype built from the same specs. Hornresp predictions have proven to be extremely accurate.
Re: Hornresp - New Website Address [message #51498 is a reply to message #51496] Thu, 25 October 2007 21:50 Go to previous message
Hi Wayne,
Many thanks for the positive feedback. It is pleasing to learn that the program has been useful to you.
Kind regards,
David
Previous Topic: My Bottlehead / Pi 5 channel system: getting there
Next Topic: 12pi basshorn subwoofer
Current Time: Mon Nov 02 04:15:52 CST 2026
