Home » Sponsored » Pi Speakers » JBL 2407
JBL 2407 [message #51477] Mon, 15 October 2007 01:07 Go to next message
bebop is currently offline  bebop
A friend gave me a pair of JBL 2407. Can I use these for a 2 ways setup and if so what is optimum crossover points for them in a home setup. Thanks for any pointer.
Re: JBL 2407 [message #51478 is a reply to message #51477] Mon, 15 October 2007 08:35 Go to previous messageGo to next message
Yes, you can use them similarly to other 1" exit compression drivers. This driver is actually a ring radiator made to drive a horn. You'll need an adapter to mount the standard 2/3 bolt pattern, JBL part number 339308-001. Crossover above 1.2kHz.
Re: JBL 2407 [message #51479 is a reply to message #51478] Mon, 15 October 2007 11:04 Go to previous messageGo to next message
I plan to cross them at 1600hz. Can I use Pi 1600hz crossover diagram (starting out with the C2, L1, etc...) for the 2407. Thanks for your help Wayne.
Re: JBL 2407 [message #51480 is a reply to message #51479] Mon, 15 October 2007 14:17 Go to previous messageGo to next message
Yes, that will work just fine.
Re: JBL 2407 [message #51481 is a reply to message #51480] Mon, 15 October 2007 22:05 Go to previous message
Thank you Wayne.
Previous Topic: Problem with PiSpeakers online store
Next Topic: theater six plan request
Current Time: Mon Nov 02 05:35:14 CST 2026
