Home » Sponsored » Pi Speakers » 12 woofer
12 woofer [message #51409] Tue, 18 September 2007 11:25 Go to next message
j.luis is currently offline  j.luis
Hy .Wayne do you believe that this Eminence 1512 with specs =Fs (41 hz) - Qts (0.65 ) - Qes ( 0.69) - Qms (8.95 ) - Vas ( 198 l) - Ebp (59.4) - Xmx ( 3mm ) - Spl ( 95 ) - Pwr (80 w ) could work in a Pi speaker . I modeled in Win Isd and give a enormous box 33 cuft but with a tuning frecuency of 21 hz using the scroll down handy option of Win Isd got a much more adequate box of 7 cuft with a tuning frequency of 37 hz . Do you believe that Pi program could give a better box ? I give thanks in advance for your much help . thanks
Re: 12 woofer [message #51410 is a reply to message #51409] Tue, 18 September 2007 14:09 Go to previous message
PiAlign suggests a 4.5ft3 (128 liter) cabinet tuned to 24Hz. It will work pretty well in cabinets from 4.0ft3 (113 liter) to 35ft3 (990 liter) tuned to 20Hz - 25Hz. You could also use it on an open or infinite baffle, perhaps mounted to one side of a room's wall, with the rear exposed to the open attic or an adjacent room.
Previous Topic: request plan
Next Topic: Cornerhorn too much?
Current Time: Sat Oct 24 23:47:32 CDT 2026
