Home » Sponsored » Pi Speakers » Pi Seven progress at last
Wiring the crossover [message #51308 is a reply to message #51307] Sat, 04 August 2007 00:58 Go to previous messageGo to previous message
Tim Barnes is currently offline  Tim Barnes
Hi Wayne:
I'm not altogether sure of the best way to install the crossover. My inclination is to keep it external so I can tweak and also to keep it clear of vibration, but I've been fiddling with the lengths of wire you provided, and I'm not sure what you had in mind in terms of the location of the crossover, as both the woofer and tweeter wires are short, while the mid-horn wire is longer.
What's the best way of running wire in and out of an enclosure? I assume I could go through the bass port, but there's no port in the mid-horn, so I guess I need to drill a hole and then seal it in some way?
I remember you saying that you set yours up so you can disassemble them for moving - did you use the stock (kit) wiring, or did you do something else?
Thanks again,
tim
Previous Topic: A rotary woofer?
Next Topic: A project I thought you'd like, Wayne...
Current Time: Fri Nov 06 02:15:40 CST 2026
