Home » Sponsored » Pi Speakers » Horn
Horn [message #51281] Tue, 24 July 2007 18:36 Go to next message
Zene Gillette is currently offline  Zene Gillette
Wayne.. Do you remember the name or web site/plans for the corner horn build in late 60's. I built from Mechanics illustrated plans. Sure was a copy of something Klipsch did. It was front firing like yours but sides were tapered into long slot facing corner. Around 48" tall if I remembered. Would love to build another set with your drivers and horns. Was the very first speaker I ever built. Damn hard project with a cheap radial arm saw in a utility room not over 6' x 6'.
Zene
Re: Horn [message #51282 is a reply to message #51281] Tue, 24 July 2007 23:09 Go to previous messageGo to next message
Maybe you're talking about the Speakerlab Khorn clone?
Re: Horn [message #51283 is a reply to message #51282] Tue, 24 July 2007 23:53 Go to previous messageGo to next message
Wayne ... Here is crude pic looking down from top, speaker on front face and a 1" wide slot in back faces corner.
Zene
Re: Horn [message #51286 is a reply to message #51283] Wed, 25 July 2007 09:32 Go to previous messageGo to next message
That looks most like an old Tannoy GRF cornerhorn. You might also look at the Jensen Imperial and JBL Hartsfield cornerhorns.
Re: Horn [message #51287 is a reply to message #51286] Wed, 25 July 2007 17:17 Go to previous message
Thanks Wayne, will do.
Zene
Previous Topic: K or Pi7 sound ?
Next Topic: Pi speakers for Home theatre
Current Time: Sat Sep 19 02:26:32 CDT 2026
