Home » Sponsored » Pi Speakers » Tweeter Attenuation on Pi 8s
Tweeter Attenuation on Pi 8s [message #51265] Sun, 22 July 2007 10:59 Go to next message
clar2391 is currently offline  clar2391
Is there a simple way to attenuate the tweeter output on the Pi 8 speakers? I'm new to all of this, but I had the same problem in this room with a pair of Magnepans, and using the tweeter resistors on the back of the Maggies helped considerably. Is there an equivalent procedure on the Pi 8 tweeters, perhaps even using the same resistors that I used on the Maggies?
Re: Tweeter Attenuation on Pi 8s [message #51266 is a reply to message #51265] Sun, 22 July 2007 16:21 Go to previous messageGo to next message
The eight π crossover has tweeter attenuation built in.
Re: Tweeter Attenuation on Pi 8s [message #51271 is a reply to message #51266] Mon, 23 July 2007 09:55 Go to previous messageGo to next message
Thanks for the quick reply. Is there a way to increase the built-in attenuation?
Re: Tweeter Attenuation on Pi 8s [message #51273 is a reply to message #51271] Mon, 23 July 2007 13:27 Go to previous message
Yes, you can change the values of R1 and R2. However, you probably shouldn't need to do this unless the speaker is used in free space, which will make it sound thin even with increased tweeter attenuation. The eight π loudspeaker should be floor-standing, against a wall or backed into a corner.
Previous Topic: 8Pi
Next Topic: pi 8 question
Current Time: Sun Oct 25 06:31:38 CDT 2026
