Home » Sponsored » Pi Speakers » Pi Seven progress at last
Pi Seven progress at last [message #51267] Sun, 22 July 2007 17:02 Go to previous message
Tim Barnes is currently offline  Tim Barnes
It took a while, but I'm finally making progress - the mid-horns are built, and the bass cabs are cut out, but not yet assembled. I made my first ever attempt at veneering yesterday - using the easy method with pre-sticky walnut and improvised tools - so far so good.
The mid-horns are finally clean enough to come inside - I prefer to do the veneering where it's clean.
I'm pre-veneering the front panels, and I may also pre-veneer the tops of the bass horns as it will be more difficult to apply sufficient pressure once they are assembled.
Still a couple of weekends before I can fire them up!
Previous Topic: A rotary woofer?
Next Topic: A project I thought you'd like, Wayne...
Current Time: Fri Nov 06 01:14:17 CST 2026
