Home » Sponsored » Pi Speakers » Damping material
Damping material [message #51237] Thu, 05 July 2007 16:18 Go to next message
rui rocha is currently offline  rui rocha
Waht kind of dumping material use use on the pi tower and how????
Two π tower - braces and damping material [message #51241 is a reply to message #51237] Thu, 05 July 2007 21:52 Go to previous messageGo to next message
Use R11 or R13 lining the line the top, one side and the front up to the woofer. You'll also want two pieces of insulation to span the cross-section. These are conveniently placed, resting on cross-braces inside the cabinet. This breaks the cabinet into three partitions, and midrange energy cannot pass through, only bass. The cross-section insulation impedes standing waves from setting up inside the cabinet.
Bracing is important in that it keeps panel vibrations to a minimum. It is important that the cabinet not add sound of its own, and you should be able to strike the cabinet with your knuckles and not hear a resonant "drum head" sound. As mentioned above, the braces also serve to hold cross-section dampers, one a third of the way up and another a third of the way down. They should be cross braces or window braces and they should double as a place to hang partitioning pieces of insulation across the cross-section of the cabinet.
Re: Two π tower - braces and damping material [message #51242 is a reply to message #51241] Fri, 06 July 2007 01:11 Go to previous messageGo to next message
Thanks wayne ,
Can you suplly a picture when i buy the kit???
for no mistakes
Best Regards
RR
Re: Two π tower - braces and damping material [message #51244 is a reply to message #51242] Fri, 06 July 2007 08:59 Go to previous messageGo to next message
This might help. I put in an extra set of braces.
Re: Two π tower - braces and damping material [message #51249 is a reply to message #51242] Sun, 08 July 2007 04:17 Go to previous message
dB is currently offline  dB
You can find this damping materials around. Another equivalent is rock wool (instead of glass). Similar properties of different materials are available like this one, COPOPREN by Recticel of 2cm thickness, a sound barrier/foam available from "Leroy Merlin" that I am going to use this year. Pay attention that the speaker was tuned already by Wayne with the first fiberglass insulation solution. I like also another (to) fluffy material used in sofas and pillows that is Polyester Fiber, available at "Mosqueteiros", etc.(many other places).
Previous Topic: Two Pi Towers with H290/PSD2002 - do-able?
Next Topic: 12pi Basshorn , assembled
Current Time: Fri Nov 20 01:30:28 CST 2026
