Home » Sponsored » Pi Speakers » Suitable top for basshorn
Re: 12π basshorn subwoofer / 9π full range top [message #51206 is a reply to message #51205] Tue, 26 June 2007 11:10 Go to previous messageGo to previous message
Each horn is to be independent of each other. This makes them more configurable for the installer. The challenge is how to make them most configurable and at the same time make them easy to setup in a building block approach. For example, with the cabinets in the shape of a truncated pyramid, they are easily splayed but they don't sit nicely on top of one another. The solution is external hardware brackets, which allow multiple placements to be possible. That's where I'm at with the design. Conceptually, it is three indepedent horns having cabinets shaped like truncated pyramids with brackets that are adjustable to allow them to sit one on top of each other or to be arrayed in groups.
Previous Topic: altec valencia n-800-F crossover
Next Topic: 7 PI CORNER HORNS
Current Time: Thu Oct 29 12:16:27 CDT 2026
