Home » Sponsored » Pi Speakers » High Efficiency 15" Woofer Suggestions For 9 Cu Ft Ported Box ??
High Efficiency 15" Woofer Suggestions For 9 Cu Ft Ported Box ?? [message #51162] Fri, 08 June 2007 14:06 Go to next message
Ka7niq is currently offline  Ka7niq
I built some sealed, corner mounted subwoofer cabinets using a super long throw 15" TC Sounds LMS 4000 driver.
They look like the Klipschorn botoms.
I was thinking of going to a higher efficiency driver in a ported arrangement.
Since these are corner mounted, an honest 30 hz response would do the trick.
Any favorite woofers that would work well in this box ?
The driver is down firing, and there is room on the bottom baffle to not only mount the driver, but place a port as well.
Re: High Efficiency 15" Woofer Suggestions For 9 Cu Ft Ported Box ?? [message #51163 is a reply to message #51162] Sat, 09 June 2007 14:39 Go to previous message
For an inexpensive bang-for-the buck solution, the Eminence Delta 15 works great. If you have a little more money to spend, you can use a JBL 2241, which is a low-distortion 18" woofer that has a shorting ring. When used in a 9ft3 cabinet tuned to 25Hz, both these woofers have a nice rising response in the bottom octave that works well for corner loading. Bass output is a conjugate for room lift and makes overall response smooth and deep.
Previous Topic: anyone tried B&C compression drivers?
Next Topic: 12 pi Subwoofers - How warm is too warm for plates
Current Time: Fri Oct 23 09:47:48 CDT 2026
