Home » Sponsored » Pi Speakers » 2Pi tower upgrade
2Pi tower upgrade [message #51141] Tue, 22 May 2007 16:48 Go to next message
Eric89GXL is currently offline  Eric89GXL
I've been the proud owner of a set of 2Pi towers for about four years now. I noticed that the design now calls for a Vifa soft dome tweeter instead of the Piezo. A few questions:
1) Can I buy an upgrade kit?
2) What is required to make the change? A x-over of some sort, obviously tweeters...
3) Why was the design change made?
4) Is it really an upgrade?
I'm going to be re-painting the speakers anyway (they got beat up from a lot of moving), so I figured I'd contemplate an upgrade. I'll post pictures once I'm done.
Thanks,
Eric Larson
Re: 2Pi tower upgrade [message #51142 is a reply to message #51141] Tue, 22 May 2007 20:22 Go to previous messageGo to next message
gumby1 is currently offline  gumby1
The Vifa tweeter is a HUGE improvement. I was really happy with the upgrade and Wayne's service is outstanding. Most highly recommended.
Re: 2Pi tower upgrade [message #51144 is a reply to message #51141] Wed, 23 May 2007 11:48 Go to previous messageGo to next message
There is a Vifa upgrade kit available for $30.00. The tweeter was changed since CTS stopped production of the earlier tweeter. The original tweeter was a great part for the price, but the new tweeter is better. It costs a little more though too.
Re: 2Pi tower upgrade [message #51145 is a reply to message #51142] Mon, 28 May 2007 08:03 Go to previous messageGo to next message
j.luis is currently offline  j.luis
Hy . do you say huge improvment can be more specific . thanks
Re: 2Pi tower upgrade [message #51152 is a reply to message #51145] Wed, 30 May 2007 07:11 Go to previous message
The Vifa is not so bright and the integration between the drivers is better. Much more pleasant to listen to. Hope this description helps.
Previous Topic: JBL 2402 Compression Driver
Next Topic: anyone tried B&C compression drivers?
Current Time: Sun Nov 01 20:52:34 CST 2026
