Home » Sponsored » Pi Speakers » Theater 4's
Theater 4's [message #51099] Mon, 14 May 2007 23:54 Go to next message
Pablo is currently offline  Pablo
I was looking at building a 2 way, with an Eminence Delta 15a, and a BMS 4540ND(or Radian 465PB) compression driver + an L-pad to bring down the Sensitivity. Crossover would be around 1k5 to 2k, built in a 5.5ft^3 box. Currently I was just thinking of using the stock eminence 2 way 1k6 crossover.
Question is, how far off is this from the Theater 4 kit minus the Eminence Compression driver? What is the crossover point of the Kit and could it be used with other compression drivers? Send me a copy of the plans so I can take a look. Thanks?
Re: Theater 4's [message #51100 is a reply to message #51099] Mon, 14 May 2007 23:55 Go to previous messageGo to next message
Should read "Thanks!"
You've got mail! [message #51105 is a reply to message #51100] Tue, 15 May 2007 11:11 Go to previous messageGo to next message
Re: You've got mail! [message #51108 is a reply to message #51105] Tue, 15 May 2007 12:24 Go to previous message
gabbe is currently offline  gabbe
hi wayne
thanks and i noted the content of your mail
zeno
Previous Topic: schematic of the x over
Next Topic: Mid-horn questions
Current Time: Mon Nov 23 03:17:16 CST 2026
