Home » Sponsored » Pi Speakers » New 10π basshorn subwoofer - Check it out
Re: New 10π basshorn subwoofer - Check it out [message #50983 is a reply to message #50778] Sat, 21 April 2007 21:52 Go to previous messageGo to previous message
Tim Barnes is currently offline  Tim Barnes
I was intrigued to learn from previous 12π discussions of the benefits of push-pull - it makes sense - I just hadn't thought about it.
Can you achieve similar benefits in a ported box with two woofers, one facing the normal way and one reversed (presumably then connected in opposite phase so they drive the external wavefront in phase)?
Have you had any thoughts about using push-pull in other designs - for example a dual-woofer corner horn with one facing into the box and one facing out? Could two cheaper woofers perform as well as or better than one expensive woofer in such a configuration?
Previous Topic: theatre 6 plans please..
Next Topic: Delta 12LF crossover in Theater 6
Current Time: Fri Oct 16 10:07:18 CDT 2026
