Home » Sponsored » Pi Speakers » six π corner horn
six π corner horn [message #50945] Sat, 07 April 2007 00:40 Go to previous message
memoose is currently offline  memoose
I have a pair of Delta 12lf waiting a project, so it limits my design options. I realize that a sand amp is basically required or a higher watt tube set up, so that will have to come later. I have been playing with Mack style Alpha 6a ten sided conical horns and will likely marry them to the corner horn. I also have picked up a pair or G2Si, but with a system approaching 101dB will they be the limiting factor at 96dB? I wanted to marry them to my Lowther Dx3s so no loss, if the recommendation is to keep the PSD2002 as a tweeter option. Does the recommended crossover integrate well with the Alphas or do you have another recommendation?
Previous Topic: 4 Pi Tweaks?
Next Topic: my two cents
Current Time: Sat Nov 21 17:44:47 CST 2026
