Home » Sponsored » Pi Speakers » port/duct position question in a simple ported system
Re: port/duct position question in a simple ported system [message #50875 is a reply to message #50869] Sun, 25 March 2007 17:31 Go to previous message
dB is currently offline  dB
Usually when the port is very long they make it even with one side of the speaker. Doesn't matter the form of the port as long as it maintains it's ratio or area, like in a circle or a rectangle. Inside you should leave some space between the port tube and the side of the enclosure like 1/2 a diameter min. Outside it's at your discretion, if you make sure is not against a wall, you can play with it.
Waves of 20Hz and below you do not hear, you can feel them.
Pay attention to the maximum displacement Xmax, you don't want to blow it with power. Check max. Xmax for speaker damage and Xmax on WinISD simulator to the maximum (red line) level allowed on the speaker.
Previous Topic: 2nd 2 Pi Tower making powerful music!
Next Topic: Pi1 / Pi3-sub system in the works
Current Time: Mon Nov 02 10:34:48 CST 2026
