Home » Sponsored » Pi Speakers » Pi 2 Tower Cross Over frequency
Pi 2 Tower Cross Over frequency [message #50796] Sun, 11 March 2007 04:24 Go to next message
Mark Andrews is currently offline  Mark Andrews
Wayne what is the ideal crossover frequency of the 2 Pi Towers?
I wind my own coils and would like to start.
Thanks
Re: Pi 2 Tower crossover [message #50800 is a reply to message #50796] Sun, 11 March 2007 14:05 Go to previous messageGo to next message
The tweeter uses a 10μF series capacitor with a 16Ω shunt damping resistor placed directly across the tweeter. The series coil in the woofer circuit is 0.5mH. No Zobel is used, so it doesn't form a true first-order crossover. The voice coil has fairly high DC resistance, so the series coil acts partially as a low-pass filter, but the voice coil also has inductance which makes it act partially like a two-coil inductive voltage divider.
Re: Pi 2 Tower crossover [message #50814 is a reply to message #50800] Mon, 12 March 2007 00:07 Go to previous messageGo to next message
Thanks Wayne.
I was going to wind new coils on my AVO winding machine but with as low a DCR as possible to ensure minimal loss in efficiency.
Would you recommending that I rather use the kit supplied unit as it is matched DCR wise too? (I have not received kit yet obviously)
Ta
Mark
Re: Pi 2 Tower crossover [message #50817 is a reply to message #50814] Mon, 12 March 2007 07:56 Go to previous messageGo to next message
The coils that come with the kits are pretty nice, but you can sure upgrade them with your own, if you like.
Re: Pi 2 Tower crossover [message #50819 is a reply to message #50817] Tue, 13 March 2007 01:18 Go to previous message
Thanks for the feedback
Mark
Previous Topic: 3 way
Next Topic: lab12
Current Time: Fri Nov 13 05:47:08 CST 2026
