Home » Sponsored » Pi Speakers » R13??
Re: Sound absorbtion [message #50816 is a reply to message #50803] Mon, 12 March 2007 06:45 Go to previous messageGo to previous message
dB is currently offline  dB
Very nice info Wayne. 5 Stars.
(Wayne, for the first time I'm going to use a 3/4" Layer of Polyurethene Foam available from Spain i.e. COPOPREN by Recticel) There are a lot of technologicaly developed new materials (sound absorbing) available.
" A promising sort of material would be one that absorbed sound (rather than re-directing the air flow as leather does). Traditional sound absorbers are fabrics, such as batting, or knotted carpets. More recently, a number of high-tech sound absorbing fabrics have been devised which may work somewhat better, and are quite a lot thinner--very important in the restricted space of a concertina end.
Sound-absorbing acoustic fabric
produces a different sound quality The material I tried is a rough ribbed polyester fabric made by JM Lynne Co. and sold on the net by Netwell Noise Control under the name "silence wallcovering" for application to the walls of rooms; it is said to be "designed for light sound absorption where the human voice and other mid range sound sources are a culprit". It is thin: 0.175" (about 4.4mm). The mill width is 54 inches, so a single linear yard at that width will cut out into a dozen or more pairs of baffles, even large ones; it is light in weight, with a linear yard (54" wide x 36") weighing 24 ounces. The fabric is available in 24 colors ( I have used black and ivory.) A yard costs USD 22.50 (GBP 15.85, EUR 25.60). See below under Suppliers.
This particular acoustical fabric is not at all air-tight--if you hold it to your lips you can blow through it just about as easily as through a single layer of ordinary t-shirt fabric. "
in www.concertina.com
(http://www.concertina.com/gaskins/baffles/)
Previous Topic: Pi 4 Stage Series plans, and a few questions?
Next Topic: Studio 2 Tower -- Theater 3 hybrid experiment
Current Time: Mon Nov 23 08:45:43 CST 2026
