Home » Sponsored » Pi Speakers » voice coil heat dissipation device
voice coil heat dissipation device [message #50802] Sun, 11 March 2007 14:22 Go to next message
nicolas is currently offline  nicolas
Wayne:
Seen your device and was wondering if a similar type device could be used with a heat dissipator coming forward thru the dust cover instead of out the back. How much heat accumulates in the rear space with the vents inside the rear space instead of going out? Have very little rear space room in present design. How about a similar design as yours with a heat dissipating plate attached to the rear wall but instead of venting into the rear space going outward past the dissipating rear plate...looks do able. Presuming the distance between speaker and rear space wall is little 1-2 inches do you think it is worth it to keep rear space as cool as possible. These will be professional use flown speakers.
Re: voice coil heat dissipation device [message #50804 is a reply to message #50802] Sun, 11 March 2007 14:56 Go to previous messageGo to next message
You can certainly mount the cooling plug in such a way as to protrude out the front of the cone and mount a radiator/heatsink there. The thing is, that will change the characteristics of the speaker somewhat because the voice coil cap won't be there. In a typical wide-range speaker, that will change the sound at higher frequencies, since the cap is the center of the radiator, a place where path length differences won't cause cancellation at high frequencies. In a subwoofer, the cap is sometimes made very rigid to make it stronger and possibly to add mass. So those are things that will change if you run the cooling plug out through the front of the speaker.
When I designed the cooling plug, my first instinct was to duct heat out of the cooling vents, rather than allowing heat to build up in the rear chamber. I expected air temperature would normally rise in a speaker with a small rear chamber used at high power levels, which would make the cooling vents less effective. My plan was to use a heat exchanger to cool the air ducted into the vents. What I found was that air temperature wasn't a big problem. The biggest problem is the heat that is retained in the magnet structure. It's like a thermos bottle, a large chunk of steel surrounded by ceramic. That's where the heat buildup is.
Re: voice coil heat dissipation device [message #50821 is a reply to message #50804] Tue, 13 March 2007 12:07 Go to previous messageGo to next message
Thanks Wayne:
We miss you at audio asylum!! Too bad for the cat and mouse games played over there at times. Remarkable results with these VC heat dissipating plates. Looks like I will not have another pro use (or even home) speaker without them. Apparently not worth having vents going outside of rear space (with the possible driver parameter changes) since most VC damage is a local heat phenomenom. Large Aluminum plate will also help dissipate rear space heat anyway.
From my days as DIY plummer I remember not to contact Cupper tubing with other metals since it leads to a chemical reaction. Therefore the use of cupper clamps to hold cupper tubing in place. Will look into this further to be sure since seems cupper tubing is ideal for wicking away VC heat out to a lightweight aluminum plate for dissipation. But likely the cupper would chemically react with the iron in the pole piece even with thermal paste in between.
Can see a big advantage in using these heat dissipating techniques not only on pro use speakers but also in high resolution dynamic low power drivers with edgewound aluminum cupper clad VC wound on cardboard etc formers. Like old Altec and JBLs.
Anyway thanks Wayne for all the free education and info and congrats on your fine speakers.
Nicolas
Re: voice coil heat dissipation device [message #50822 is a reply to message #50821] Tue, 13 March 2007 14:19 Go to previous messageGo to next message
Please feel welcome to participate on the π Speakers forum and all the other forums on AudioRoundTable.com. No matter where you are, we're only a few keystrokes away.
GALVANIC CORROSION [message #50824 is a reply to message #50804] Wed, 14 March 2007 06:25 Go to previous messageGo to next message
dB is currently offline  dB
I was readind this post and Wayne have in fact excelent information. Congratulations, one more time.
The name for this kind of corrosion is Galvanic Corrosin. Also very important is corrosion under stress. Look under "Galvanic Corrosion Tables". There are very nice ones. I had a problem with corrosion of magnesium speakers (maybe is better to get nuts and bolts of similar material or then use nylon spacers).
*nice read: Fastener Design Manual - http://www.tcnj.edu/~rgraham/barrett/manual1-A.html
PICTURE FROM: http://ops.dot.gov/regs/small_ng/images/chapter3_table.png
Re: voice coil heat dissipation device [message #50833 is a reply to message #50822] Thu, 15 March 2007 12:18 Go to previous messageGo to next message
WILL VISIT OFTEN nt is currently offline  WILL VISIT OFTEN nt
NT
Re: GALVANIC CORROSION [message #50843 is a reply to message #50824] Sun, 18 March 2007 17:27 Go to previous message
Thanks dB saved me some time!! Seems that there is little chemical potential difference between pure mild steel (clean fresh)and commercial Aluminum but significant difference between Cupper and Iron. Therefore seems that as Wayne has used pure commercial Aluminum is the best all around choice..
Again Thanks.
Previous Topic: Damping stuff
Next Topic: Midhorn placement question
Current Time: Wed Nov 18 01:04:48 CST 2026
