Home » Sponsored » Pi Speakers » One last question
One last question [message #50741] Mon, 26 February 2007 15:35 Go to next message
xcortes is currently offline  xcortes
I had to speed up the finishing of two of my five pi pro fours because I had an issue with a pair of speakers from my "main" system. During the weekend I finished and painted the cabinets. The crossover networks are ready. Tonight I only need to cut and staple the insulation and put the drivers in. I have always soldered the inner wire to the drivers in other speakers I've made. I notice that you don't but rather use some connectors. While I appreciate the benefits of connectors that you can put on easily I like the connection you get soldering the driver. Any advice against this practice? (Also I don't have connectors and I need to finish these speakers!)
thanks,
xavier
Re: One last question [message #50742 is a reply to message #50741] Mon, 26 February 2007 16:52 Go to previous message
I used to be kind of picky about soldering everything too. Mechanical connectors seemed to me to be the place where problems creep in, so I did away with them. But then I realized that as long as the physical contact is good, no corrosion or electrolysis, then there is really nothing wrong with a mechanical connection. The benefit of ease of maintenance makes it worthwhile to me. As with all things, you trade one thing for another. I think there is a benefit in having the connectors on speakers, so I use them.
Previous Topic: JBL 2450H
Next Topic: My first crossover network: pic and questions
Current Time: Mon Nov 23 02:04:21 CST 2026
