Home » Sponsored » Pi Speakers » Blow Fuse!
Blow Fuse! [message #50561] Sun, 21 January 2007 08:33 Go to previous message
Tuffer is currently offline  Tuffer
Hi Guys,
I have been borrowing some of your crossover designs to try and improve my speakers which are used for mainly DJ use. I am using a Beyma 15G40 and PSD2002 in a vented box. I am using an Eminence PXB2:1k6 crossover.
I have created an lpad using two 15 ohm resistors and a 0.47uf cap for compensation. The resistors are wirewound and so may be inductive. See a pic below.
http://www.tuffer.co.uk/cross1.jpg
I have also disconnected one end of the 10uf cap on the crossover to give me a pseudo first order filter on the woofer.
http://www.tuffer.co.uk/cross2.jpg
Was quite happy with the results. Attenuation is perhaps a little strong. 8db might have been better.
On their first proper outing however both the fuses on the crossover board blew. They were being powered by a Behringer EP2500 so about 450w max to each cab. I wasn't present when they blew but was told that they weren't being driven particularly hard. I had been using these crossovers without the lpad or mod for some time without any problems.
Can anyone tell me if what I have done looks OK ? Could any of these changes increased the likelihood of overload and the fuses blowing or is it just one of those things that happen ? Should I just replace them with stock Eminence fuse or something else ? Obviously while the fuses have done there job and protected the HF drivers I wan't these cabs to be as reliable as possible.
Thanks for your help.
Previous Topic: Stage, Audiphile(?) or Professional?
Next Topic: First listen to the 3-way; I call them the......
Current Time: Wed Nov 04 22:34:34 CST 2026
