Home » Sponsored » Pi Speakers » Pi Studio One Tower
Side Firing Sub [message #50510 is a reply to message #50504] Thu, 11 January 2007 04:44 Go to previous messageGo to previous message
Good idea! If I were doing this I probably would use a different design from the One Pi, with an Eminence Beta 8 in a sealed chamber instead of the Alpha 8 in a ported one. The Beta 8 has greater power handling capacity and it will perform well in a sealed box as small as 0.3 cu ft.
A good economical woofer section could include the Dayton 10" DVC sub that's on sale for $25. You could drive it with the 75 watt MCM plate amp that's now on sale for $40. The Dayton DVC sounds really good in a 1.5 cu ft sealed enclosure, so everything would fit fine in the original One Pi Tower enclosure with the mid, tweeter section sealed off from the woofer section just below the Beta 8.
Here's another idea that would be helpful if you were driving this with flea power SET amps like my Paramours. You could drive the subs' plate amps directly from the line output of the preamp and insert a passive high pass filter at each SET amp's input to roll off it's output below 100hz. Relieving the amps of low bass duty would enhance their ability to drive the Beta 8's.
Now I'm confused about which version of the enhanced One Pi tower I should build:)
Previous Topic: Pi 4 plans request
Next Topic: 3pi sub plans
Current Time: Thu Sep 24 11:00:53 CDT 2026
