Home » Sponsored » Pi Speakers » Eminence PSD2002 vs JBL 2426h
Eminence PSD2002 vs JBL 2426h [message #50322] Wed, 29 November 2006 10:32 Go to next message
lovehorns is currently offline  lovehorns
Hi,
I noticed many of the designs here use these drivers and some of them indistinctly. Can you tell me what differences in sound are there between them? Do you think the difference justifies a price for the JBL which is 5 times? Under what circumstances would you use the PSD2002 instead of the 2426H?
Thanks
lovehorns
Re: See different tweeters and woofers about 3 lines down. nt [message #50323 is a reply to message #50322] Wed, 29 November 2006 10:58 Go to previous messageGo to next message
Re: What are 2426's faults? [message #50325 is a reply to message #50323] Wed, 29 November 2006 12:54 Go to previous messageGo to next message
"It doesn't have the mid-range clarity of the JBL 2426, the air and extension of the Altec 902 or the detail of the BMS. But it also has none of their faults"
thanks
Re: What are 2426's faults? [message #50330 is a reply to message #50325] Wed, 29 November 2006 17:25 Go to previous messageGo to next message
spkrman57
2426 has a lower high frequency roll-off compared to Altec 902.
2426 has a nicer upper midrange compared to the 902.
The others are basically a lower mix of both drivers with maybe a bit more distortion and less flat response.
I like the 902 drivers myself. If I used a 2426, I would add a tweeter and have the best of both.
Regards, Ron
Re: What are 2426's faults? [message #50331 is a reply to message #50325] Wed, 29 November 2006 17:26 Go to previous message
To my ears, a sharper roll-off above 12kHz which makes it less 'airy' than others. With a super-tweeter like the 2405 the combination is better than most.
Previous Topic: Midhorn Input Data
Next Topic: 4 Pi Theater Plans
Current Time: Tue Nov 03 06:36:02 CST 2026
