Home » Sponsored » Pi Speakers » mid-horn
mid-horn [message #50317] Mon, 27 November 2006 18:45 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy Wayne . I need your oppinion Wayne because I want to make the seven pi mid-horn 25 % larger to fit the dimensions of another bass bin with a width of 30 inches .Does rise problems Wayne if I make the mid-horn instead of the recomended 12 X 24 to a 15 X 30 inches making the other measurements according . thanks for your help again. Wayne
Re: mid-horn [message #50319 is a reply to message #50317] Mon, 27 November 2006 20:06 Go to previous message
I'd suggest modeling your proposed changes with Hornresp. It really does a good job of simulating response. I'd expect that if you increase length just a little bit as well as increasing mouth area, you'll probably have a very good horn.
Previous Topic: 12pi Plans
Next Topic: Midhorn Input Data
Current Time: Sat Nov 07 09:45:33 CST 2026
