Home » Sponsored » Pi Speakers » 8 Pi Question ?
8 Pi Question ? [message #50282] Tue, 21 November 2006 09:27 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy again Wayne . Im considering to make only 1 round port ( I sum the three rectangular areas of the front ports ) and calculated a round port of 4 5/8 in the back of the 8 pi cabinet .my question is what if i throw the port into the corner of the room near a few inches could have a gain instead of the three front ports firing into the open room . thanks
Re: 8 Pi Question ? [message #50286 is a reply to message #50282] Tue, 21 November 2006 11:24 Go to previous messageGo to next message
You can make the port in a different shape, and positon doesn't matter as long as it doesn't cause standing wave pipe behavior.
Corner loading works at bass frequencies several feet away from the apex, so a port on the front of a corner-loaded speaker will act the same as one on the back unless the speaker is several feet deep.
When a sound source is placed at the apex of a trihedral corner, it radiates purely into eighth-space. The walls of the corner define the radiating angle. In this situation, the walls don't act as reflectors because a wavefront travels along them or away from them rather than towards them and reflected by them.
When a sound source is near a boundary, then it confines the radiating area and also acts as a reflector. At low frequencies, where the distance to the boundary is less than 1/4λ, the boundary constrains the radiating angle without any anomalies in frequency response. Above 1/4λ distance, the boundary begins to act as a reflector and peaks and dips will occur at 1/4λ multiples.
The end result of all this is that woofers and ports can be placed fairly far away from corners and still radiate into eighth-space.
Re: 8 Pi Question ? [message #50299 is a reply to message #50286] Wed, 22 November 2006 15:10 Go to previous messageGo to next message
Hy What cause standing waves pipe behaivor Wayne ?
Re: 8 Pi Question ? [message #50311 is a reply to message #50299] Fri, 24 November 2006 16:58 Go to previous message
Standing waves are what give a pipe organ its sound. The length of each pipe tunes its frequency. This is also the principle at work in transmission lines.
Previous Topic: What do you make of this "white paper"?
Next Topic: 7pi mid-horn
Current Time: Fri Nov 13 05:42:36 CST 2026
