Home » Sponsored » Pi Speakers » Which Pi kit
Which Pi kit [message #50090] Tue, 26 September 2006 13:50 Go to next message
Bob is currently offline  Bob
Hello,
I have given up my High end Magnepans for some old Bozaks I like the feel of real bass. I lovem and figure I would like to upgrade to some modern 12" or 15" woofer beasts, than can outdue the bozaks.
I have a few amps from a Fi 2a3, mint dynaco st70, Odessey mono amps (185 watts high current) and a Mc MC2205 (200watts), so I pretty much have a good choice to find the best amp to match. My room is 24 long 14 wide 10' high. I listen to clasic rock most of the time and Blues the rest sometimes some of that joss stone kind of music, .
I will be buiding the cabnets myself.
Can someone sudgest which kit is best for me? also cabinet plans, size is not a problem I dont want to be stuck with corner horns. Also do you think these will best the Bozaks...I have the Concerto 3001 its the 12" 199 woofer and a three 200 tweeter aray. in a 5' infinit baffle enclosure I wouldn want to wast my time. Unfortunatly I have never herd any of the Pi speakers on read about them
Thanks
Bob
Re: Which Pi kit [message #50095 is a reply to message #50090] Wed, 27 September 2006 08:31 Go to previous messageGo to next message
For a simple and inexpensive speaker, I'd suggest the two π tower speaker. For the all-out best, I'd go with the Professional Series seven π. If you don't want to be set to corners, you can use the four π cabinet as the bass bin and run the midhorn and tweeter from the seven π on top. The Theater Series three π and four π loudspeakers are good mid-level models.
Re: Which Pi kit [message #50096 is a reply to message #50095] Wed, 27 September 2006 08:36 Go to previous messageGo to next message
Got it, I would go with the four cabinet with the 7 parts, can you send me the four cabinet plans.
When I sell my magies I will purchase these
Thanks
Bob
You've got mail! [message #50097 is a reply to message #50096] Wed, 27 September 2006 17:09 Go to previous messageGo to next message
Re: You've got mail! [message #50098 is a reply to message #50097] Wed, 27 September 2006 19:57 Go to previous messageGo to next message
catfish is currently offline  catfish
I would like a copy of those plans as well.
Thanks!
You've got mail too! [message #50099 is a reply to message #50098] Wed, 27 September 2006 20:11 Go to previous messageGo to next message
Re: You've got mail too! [message #50126 is a reply to message #50099] Wed, 04 October 2006 19:29 Go to previous messageGo to next message
mark_ivan is currently offline  mark_ivan
Hi
This sounds pretty intriguing. I am interested in building one of your kits to mate up with some Bottlehead gear, don't have the room for corner loading, but want the best speaker sound I can get for around $1k (building my own cabinets if fine). Could you please send the plans to me as well?
Thanks
And you! [message #50129 is a reply to message #50126] Wed, 04 October 2006 23:59 Go to previous message
Previous Topic: Eminence driver issues
Next Topic: resonance ?
Current Time: Sun Oct 25 06:32:07 CDT 2026
