Home » Sponsored » Pi Speakers » speaker wire gauge
speaker wire gauge [message #50115] Mon, 02 October 2006 20:58 Go to next message
Paul is currently offline  Paul
I am wiring my home theater this week using in-wall speaker wire. The longest connection I am making from amp to speaker will be about 25 feet. What gauge of speaker wire should I use?
thanks
Paul
Re: speaker wire gauge [message #50116 is a reply to message #50115] Tue, 03 October 2006 00:21 Go to previous messageGo to next message
I often use PA and Musical Inst gear with speaker wire runs of 25'-50'. For 25' 16 ga should be more than adequate.
Re: speaker wire gauge [message #50117 is a reply to message #50116] Tue, 03 October 2006 03:13 Go to previous messageGo to next message
Zene Gillette is currently offline  Zene Gillette
Why 16 gage. 12 gage is pretty much standard for all but sub-woofers. Doesn't cost much more than 16. Don't use the minimum required. Zene
Re: speaker wire gauge [message #50119 is a reply to message #50117] Tue, 03 October 2006 08:48 Go to previous messageGo to next message
The power levels you'll be running will make a difference. Typically, at normal listening levels, 16 awg would be adequate. But, if you are using inefficient speakers driven by big amplifiers (high current levels), then the larger awg wire would be best.
Subwoofers often consume a lot of current, hence the 12 awg wire.
Re: speaker wire gauge [message #50121 is a reply to message #50119] Tue, 03 October 2006 13:42 Go to previous message
Sorry, I was not clear. I would consider 16 awg the minimum, but adequate. Of course larger would be better.
Previous Topic: multiple driver manifold for horn loading...
Next Topic: plans 12 horn
Current Time: Mon Nov 02 04:56:19 CST 2026
