Home » Sponsored » Pi Speakers » OT: Computer Audio
OT: Computer Audio [message #50047] Wed, 20 September 2006 12:55 Go to next message
Any recommendations on quality computer audio (on the cheap)?
I thought about building a pair of small FE-103E based monitors, but I'm not sure I want to wait until I can build them (since I would also have to build and amp). Plus, Fostex doesn't provide much bass unless horn loaded. So then I thought I'd just pick something up from Best Buy, but their stuff is all so cheap and cheesy (ironically enough, JBL is the cheesiest).
I may ultimately do a pair of Fostex based monitors powered by a chip-amp, but I wanted to get some opinions from the peanut gallery (that's you guys) first. Any siggestions?
Oh, < $100.
Re: OT: Computer Audio [message #50050 is a reply to message #50047] Wed, 20 September 2006 14:31 Go to previous messageGo to next message
That's the direction I'd probably go. A small high-efficiency driver that doesn't require a large cabinet.
Re: OT: Computer Audio [message #50052 is a reply to message #50050] Thu, 21 September 2006 08:32 Go to previous messageGo to next message
Could you recommend a compact subwoofer design/driver that would match well with the Fostex drivers? Something that might work in the 1-2cu.ft range.
Re: OT: Computer Audio [message #50053 is a reply to message #50052] Thu, 21 September 2006 09:08 Go to previous messageGo to next message
I'd look at the HL10 from Eminence.
Re: OT: Computer Audio [message #50056 is a reply to message #50047] Thu, 21 September 2006 14:15 Go to previous messageGo to next message
Funny, I'm on that same quest. My plan at the moment is to use some RS 40-1197's (cheap Fostex FE-103s) that I have and some Dayton dome
tweets to make MTM config L/R speakers and use a sub with them. I'm considering preamp and amps from http://www.dckits.com/audio.htm.
PartsExpress has something similar on sale for $50/pr.
Chris
Re: OT: Computer Audio [message #50057 is a reply to message #50047] Thu, 21 September 2006 14:42 Go to previous messageGo to next message
If you're going for cheap and easy, pick up a SonicImpact T-amp.
Check out Zaph's page for mini desktop speakers.
Very Cool [message #50059 is a reply to message #50057] Thu, 21 September 2006 15:40 Go to previous messageGo to next message
His stipulation on teh sub-woofer may cause problems long term, though.
Thanks [message #50060 is a reply to message #50056] Thu, 21 September 2006 16:26 Go to previous messageGo to next message
Thanks for the lead. A LM3886 based system was exactly what I was thinking of.
The only quesiton I had was the sub, but it looks like those kits will cover that problem as well. If the speakers that GarMan recommended are less than the Fostex's, then I may go that route with the DC kits stuff. Either way, I think we have a winner.
Re: OT: Computer Audio [message #50069 is a reply to message #50057] Fri, 22 September 2006 08:10 Go to previous messageGo to next message
Those drivers are extremely in-efficient. What would be the best way to drive them? Have you heard them?
Re: OT: Computer Audio [message #50070 is a reply to message #50053] Fri, 22 September 2006 08:47 Go to previous messageGo to previous message
Ouch. A bit expensive for what I'm trying to do. Do you have any recommendations in the $50 range? Or less?
Previous Topic: pi x over
Next Topic: Cooling plug - Driver preparation
Current Time: Fri Nov 13 07:26:11 CST 2026
