Home » Sponsored » Pi Speakers » Bass trapping with corner horns
Bass trapping with corner horns [message #49973] Tue, 05 September 2006 21:02 Go to next message
jimbop is currently offline  jimbop
What are suggestions/recommendations for implementing bass traps when using the Pi Seven coner horns?
Currently I have bass traps in the front corners of my room, and don't really have true "corners" at the rear of the room.
JD
Re: Bass trapping with corner horns [message #49978 is a reply to message #49973] Tue, 05 September 2006 22:08 Go to previous message
Use CARA to model your room and find out where your nodes line up. With four cornerhorns, you'll have a very large listening area that is uniform throuout the bass. Even with just two cornerhorns, there is a large area of uniformity. In either case, response above the modal region is uniform throughout the room.
Bass traps are dampers. Framed drywall construction tends to make highly damped rooms too. If your listening room is of framed drywall construction, it may already be highly damped. In a sense, the drywall and the fiberglass behind your walls forms a built-in bass trap.
You can include room damping in your CARA model, or remove damping to exaggerate room modes to see them better.
Previous Topic: Theater 3 baffle size and driver arrangement
Next Topic: Learned some more audio truth outdoors
Current Time: Thu Nov 12 02:51:24 CST 2026
