Home » Sponsored » Pi Speakers » Theater 3 baffle size and driver arrangement
Re: Theater 3 baffle size and driver arrangement [message #49970 is a reply to message #49953] Tue, 05 September 2006 15:50 Go to previous message
Chris,
If you arrange the woofer and tweeter side-by-side, instead of one on top of the other, you'll have to live with poor horizontal off-axis response.
With traditional vertical stake, it assumes you're head will be at a certain height, but allows you to move side to side with little change in response. Putting the drivers side-by-side will allow you to stand-up or lie-down on the floor to listen, but limit your side to side listening position.
Previous Topic: Help Choosing the right Pi
Next Topic: Bass trapping with corner horns
Current Time: Thu Nov 26 11:09:01 CST 2026
