Home » Sponsored » Pi Speakers » Larger Driver
Larger Driver [message #49934] Sun, 03 September 2006 00:17 Go to next message
Zene Gillette is currently offline  Zene Gillette
Hi ... What are the negative points for using a bigger driver on a horn that was originally designed for 8" driver? Horn is from JBL SR4735X. http://www.jblproservice.com/pdf/SR-X%20Series/SR4735X.pdf
Throat is 19 sq. in. Normal Sd/St was 2.43. I would like to use a 10" driver, but Sd/St would be 3.5. BTW will use open chambered. Thanks, Zene
Re: Larger Driver [message #49936 is a reply to message #49934] Sun, 03 September 2006 15:09 Go to previous messageGo to next message
Model it using Hornresp. You can probably find a driver that will work for you. Just by looking at it, I think a JBL 2012 or Eminence Delta 10 would probably sound good on that horn. Might be worth a try.
Re: Larger Driver [message #49937 is a reply to message #49936] Sun, 03 September 2006 18:47 Go to previous messageGo to next message
Saved my bacon again. Speaker I was thinking about had xMax of 1mm. Now I realize that could be awful without back chamber. Will get very friendly with HornRes. Footnote ... My reconer says the Eminence vc lead outs are breaking too often. He's quit recommending them for band use. May or may not be a concern for home. Thanks, Zene
Re: Larger Driver [message #49940 is a reply to message #49937] Sun, 03 September 2006 20:12 Go to previous messageGo to next message
Eminence's pressed-frame drivers have spade lugs on cardboard mounting tabs. That's pretty common for inexpensive speakers, and I agree, you don't want to put any pressure on them. I give them some support underneath with my finger when pressing on the connector 'cause they'll break if unsupported.
Eminence's cast-frame drivers use much more durable connectors.
Re: Larger Driver [message #49943 is a reply to message #49940] Sun, 03 September 2006 23:11 Go to previous messageGo to next message
Wayne ... It's not the terminals it's the leads that connect direcly to the vc. Explaination was they don't have strain relief so they vibrate until they break. Eminence is aware of problem so is not minor. Can send you one if it's of any importance. Might not be if you've had no problems. Zene
Re: Larger Driver [message #49944 is a reply to message #49943] Mon, 04 September 2006 11:02 Go to previous messageGo to next message
I'm not aware of that problem and I've done some pretty intense tests of Eminence drivers. Like most other speakers, the leads from terminals to cone are looped to allow for excursion. What driver have you encountered this kind of failure from?
Re: Larger Driver [message #49946 is a reply to message #49944] Mon, 04 September 2006 15:27 Go to previous messageGo to next message
Wayne ... I will get a proper report from my reconer so I don't try to describe something I'm not qualified to comment (on). Zene
Re: Larger Driver [message #49948 is a reply to message #49946] Mon, 04 September 2006 21:16 Go to previous messageGo to next message
Jerry McNutt at Eminence says there have been no unusual problems related to connectors or leads breaking in any of their drivers. This just hasn't been a problem for them.
Re: Larger Driver [message #50025 is a reply to message #49948] Wed, 13 September 2006 23:43 Go to previous messageGo to next message
Wayne ... Once I get the full story I will start new thread. Zene
Re: Larger Driver [message #50026 is a reply to message #50025] Thu, 14 September 2006 01:09 Go to previous message
I've had my share of problems with Eminence drivers over the years, but connection wires haven't been an issue. It's more likely that something else is going on.
Previous Topic: Super Tweeter?
Next Topic: Light bulbs
Current Time: Sat Oct 31 06:23:21 CDT 2026
