Home » Sponsored » Pi Speakers » Help Choosing the right Pi
Help Choosing the right Pi [message #49929] Wed, 30 August 2006 05:26 Go to next message
LeeW is currently offline  LeeW
I'm going to put together a 2 channel system using a SET 300B amp. I'm currently using Adire HE.10's that are going to stay in the home theater.
What Pi speakers are others using with the 300B and also what preamp are you using.
Thanks,
Lee
Re: Help Choosing the right Pi [message #49930 is a reply to message #49929] Wed, 30 August 2006 15:10 Go to previous messageGo to next message
I'm amazed at the list compiling in my head. Let's see, specifically with 300B I've used Theatre 4 Pi, Studio 2 Pi with Piezo, Vifa DX-25 and Morel tweeters, Studio 2 Pi Tower, and Theatre 4 Pro.
Money talks, the Theatre 4 Pro is best followed by the Studio 2 tower.
If you have the corners there's no doubt the 7 Pi configs are best.
But in the end, you'll have to judge.
Re: Help Choosing the right Pi [message #49931 is a reply to message #49930] Thu, 31 August 2006 05:47 Go to previous messageGo to next message
Bill,
I was leaning towards the Theater 4, the Pro 4 has a smaller cabinet which I like, But is it that($$) much better than the Theater 4?
would you rate the Studio 2 Towers over the Theater 4?
Thanks,
Lee
Re: Help Choosing the right Pi [message #49932 is a reply to message #49931] Thu, 31 August 2006 10:17 Go to previous messageGo to next message
I'd say let your budget be your guide- the Tower 2's are great, and are one of the best bargains out there in speakers. As you move up, you'll get a fuller sound and more definition. I have the Stage 4's, played with 2A3 tubes (less power than 300B), and they sound great. Smaller cabs than Theater series, if that's a factor. With the 300B's, you can go with any of these, or the Pro series w/ JBL's. There are a lot of posts about each in the archives. Good luck!
Re: Help Choosing the right Pi [message #49938 is a reply to message #49932] Sun, 03 September 2006 18:52 Go to previous messageGo to next message
Thanks for the responses, I decided to go with the Premium 4's
Wayne can you email the drawings?
Thanks,
Lee
You've got mail! [message #49939 is a reply to message #49938] Sun, 03 September 2006 20:08 Go to previous messageGo to next message
Re: You've got mail! [message #49941 is a reply to message #49939] Sun, 03 September 2006 20:13 Go to previous messageGo to next message
Wayne,
Does the port come with the kit or is it made from wood?
Thanks,
Lee
Re: You've got mail! [message #49942 is a reply to message #49941] Sun, 03 September 2006 20:16 Go to previous message
It's rectangle shaped and made from wood in that model.
Previous Topic: JBL 2115s 4 Sale
Next Topic: Theater 3 baffle size and driver arrangement
Current Time: Wed Nov 04 01:48:35 CST 2026
