Home » Sponsored » Pi Speakers » Say Wayne; What Do You Mean BY Wood Tweeter Horn?
Give us the "pitch"... [message #49905 is a reply to message #49904] Mon, 21 August 2006 18:37 Go to previous messageGo to previous message
Greggo is currently offline  Greggo
Wayne,
I seem to recall a little more excitement and detail leading up to the launch of certain speaker models, mid horn, and bass horn... I think others would share my enthusiasm in learning more about your plans for this horn tweeter. If you are being careful with competitive issues, that is fine, but if not....
1) Good options for high efficiency tweeters seems hard to come by, I recall you will only be selling these as complete horns rather than kits. Is this just the horn or horn plus a driver that you intend to market?
2) Tell us a little about what inspired you to come up with something specific here, anything that in your mind makes this offering a bit different from the other options out there?
3) Have you done any prototype testing with any specific compression drivers? Plan on recommending the same compression drivers that are part of your kits now or are there others you would recommend for use with this horn?
4) What frequency range do you feel is the best fit for your new horn tweeter?
5) Price plan/options, if still waiting for details on manufacturing costs, then at least a ballbark or range based on what you know thus far?
I think there is a good chance I will be ordering a speaker kit from you soon, and even if I don't, then there is a good chance I will order this tweeter (combo?) horn as part of my own diy project, that is assuming you can convince me (and it normally doesn't take much...) that this is a smoother, more dynamic, and more readily integrated with the directivity at crossover of a mid horn or a 10-12 inch pro woofer/midrange cone driver.
Come on Wayne, don't be humble, get us fired up over this latest project of yours!!!
Regards,
Greg Jensen
Asheville, NC
Previous Topic: New Horn Tweeters? (and any impact to 3 pi designs???)
Next Topic: Prosound Shootout
Current Time: Wed Nov 04 12:45:13 CST 2026
