Home » Sponsored » Pi Speakers » xover
xover [message #49871] Wed, 16 August 2006 19:18 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy Wayne .A a few posts do you said that the Beta 15 could work in a Theater four box .My election for the tweeter is the ASD 1001 I want to Xover in the region of 2k TO 2.5K .do you have a design for this x-over point .thanks in advance for your help .
Re: xover [message #49872 is a reply to message #49871] Wed, 16 August 2006 23:17 Go to previous messageGo to next message
Sorry, no. Seems like I always strike out with you, Luis. I don't have a crossover design for a setup like that. You might want to re-think it though, because the midwoofer will have a very narrow pattern beyond 2kHz. Off-axis tonal balance will be poor and the reverberent field will not be uniform. Can you use the PSD2002 instead?
Re: xover [message #49875 is a reply to message #49872] Thu, 17 August 2006 08:41 Go to previous messageGo to next message
Thanks Wayne . I will take you guidelines PSD 2002 is the tweeter to use .thanks again Wayne
Beta15 in theater 4 box [message #49878 is a reply to message #49871] Thu, 17 August 2006 12:46 Go to previous messageGo to next message
AudioLapDance is currently offline  AudioLapDance
Hey,
I threw some beta15s into my theater 4 corner horns (tall, wide and thin 5 cuft box, tuned to 40hz) and they sounded really boomy (in corners and out).
Boxplot says that the beta in a 5cuft/40hz box should only have a 4db bump at 80hz which should sound good and punchy. For some reason that's not what I heard?!? Go figure??
Give it a try and tell us what you hear.
Regards,
Jeff
Re: Beta15 in theater 4 box [message #49879 is a reply to message #49878] Thu, 17 August 2006 18:55 Go to previous messageGo to next message
Hy A.L.D regarding the Beta 15 only will live in very big boxes 20 to 30 f3 modeling with WinISD 34 F3 will give a fabolous response in the 24 hz in a box . After more modeling I found that a box of 36 x 24 x 18 internal measurements with a port of 6 x 2.75 will give a very acceptable tunning frecuency of 34 hz but still a very big box but here the Beta 15 can breath much more . just do it
Re: Beta15 in theater 4 box [message #49881 is a reply to message #49879] Thu, 17 August 2006 22:21 Go to previous message
The Theater four π (and seven π bass bin) is a little over 8ft3 and tuned to 25Hz. This cabinet, when used with a Delta 15, gives a response curve somewhere between overdamped and EBS. This is a nice curve for use in rooms with boundary reinforcement, such as against walls or in or near corners.
When substituting the Beta 15 in the same cabinet, response does indeed shift towards being slightly less damped. It develops a slight hump in the midbass. That is a direction you don't want to go in a corner speaker, but I don't think it would sound bad in an open space, pulled away from walls a few feet. But if the cabinet is smaller than 8ft3 - certainly if it is only 5ft3 - the Beta 15 will be too underdamped and will sound boomy no matter where the speaker is placed.
Previous Topic: Heeere's Wayne!
Next Topic: Alpha 10 for mihorn?
Current Time: Mon Jul 15 16:16:29 CDT 2024
