Home » Sponsored » Pi Speakers » Acoustic Suspension Pi and.....ta-daaaa...my new horn
Acoustic Suspension Pi and.....ta-daaaa...my new horn [message #49856] Sat, 12 August 2006 13:32 Go to next message
Those unfinished speakers I showed playing outside got the veneer treatment this week. While I was at it I cut discs the size of the ports and sealed them. just to see if maybe Villchur was on to something.
They sound so good I even commented over on Bottlehead where SET friendly is a constant quest. And a mention of Pi Speakers couldn't hurt.
Wayne, What happened to the 3Professional Matts mentioned with JBL 12" 2206. Gone?
These are very Studio 2 Pi like, 1.35 cu ft inside with the Vifa DX-25 but an Altec/University 12" Speakerman "donated".
I think sealing brought the woofer level down more in line with the Vifa and all trace of the boomy bass is gone but fingers plucking double bass strings are very clear.
There is a little "boxy" coloration: more with the solid waste A/V receiver and much less with the revised Dignity Audio 300B's I just received.
And ladies and Gentlemen, Mesdames et Monsieurs, Damen und Herren....
My New (used) horn -
A late '60's Conn 50H I won on E-bay last night against some pretty wimpy (or smarter than me) bidders
Re: Acoustic Suspension Pi and.....ta-daaaa...my new horn [message #49858 is a reply to message #49856] Sat, 12 August 2006 16:31 Go to previous messageGo to next message
Pretty cool, Bill! What are the specs on that Altec woofer, do you recall?
The Professonal Series three π is a neat little mini-monitor and it sounds very nice. But it didn't really fit with the rest of the line so I never made it available on the shopping cart. It's basically a JBL 2206 and Vifa DX25 in a cabinet the size of a two π, 22"x15"x10" with a 3" diameter port just under 2" long. First-order crossover like the one π and two π Speakers.
Re: I'm working on that boxiness [message #49859 is a reply to message #49858] Sun, 13 August 2006 07:15 Go to previous messageGo to next message
Kind of a 'hollow' sound.
I took apart the third order BW and left it crossed at 3000 with just the 13.25 cap first order. Then swapped out the 1 mH coil replaced it with .5 on the woofer. Textbook.
We'll see if that helps.
Re: I'm working on that boxiness [message #49860 is a reply to message #49859] Sun, 13 August 2006 09:59 Go to previous messageGo to next message
hitsware is currently offline  hitsware
How do you have them stuffed ?
Altec/Utah 12" specs [message #49861 is a reply to message #49858] Sun, 13 August 2006 11:56 Go to previous messageGo to next message
spkrman57
They measure exactly like the Altec 414 driver.
The 414 is a cast frame driver with larger magnet though.
Utah must have gotten together with Altec near the end to come up with a driver similiar to the 414, but at a much cheaper price.
They are more common than most people think!
Ron
Re: Stuffing [message #49863 is a reply to message #49860] Sun, 13 August 2006 12:15 Go to previous messageGo to next message
3 walls R-13 and then 2 big handfuls of dacron batting loose
Re: I'm working on that boxiness [message #49864 is a reply to message #49859] Sun, 13 August 2006 12:28 Go to previous messageGo to next message
Yeah, I like to use a first-order crossover on that tweeter. The DX25 has a wide surround and can handle the shallow crossover slope. I use a 10uF cap on the tweeter and a 0.5mH coil on the midwoofer in the one π and two π speakers.
Re: Stuffing [message #49865 is a reply to message #49863] Sun, 13 August 2006 12:37 Go to previous messageGo to next message
Was that scheme planned for the BR, or the sealed? It seems (for some reason?) that usually sealed boxes are really 'stuffed' while BR's are 'lined'. If they sound "hollow" then a more robust stuff job might help.....
Re: I'm working on that boxiness [message #49866 is a reply to message #49864] Sun, 13 August 2006 19:17 Go to previous message
.5 mH coil is a winner.
Going to first order maybe makes a little more detail but i'm sure the banishment of the 'hollow 'boxiness' sound is having the right coil.
Previous Topic: Some basic questions about Pi web site and speakers:
Next Topic: studio 2 PI
Current Time: Thu Sep 12 00:43:29 CDT 2024
