Home » Sponsored » Pi Speakers » box
box [message #49839] Thu, 10 August 2006 10:19 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy Wayne . I must use the Beta 15 because get them very cheaply here in eminence mexico dealer . So after modeling using WinIsp give a box of 11.25 f3 tuned to 25.6 hz with twin 4x6 ports . My question Wayne Is this modeling through WinIsp according with your Pi aligmnment . Oh what say the Pi modeling to this woofer with this specs--- fs 35 ---Qms 8.10 ---Qes 0.63 ---Qts 0.58 ---Vas 334.4 ---Xmax 4 mm ---pwr 300 -- .thanks for your help.
Re: box [message #49844 is a reply to message #49839] Thu, 10 August 2006 12:12 Go to previous messageGo to next message
I understand. The Betas are pretty good drivers. I used to use them but felt there was too much overlap in my product lines so I dropped them. As I recall, the Beta 15 would work pretty well in a Theater Series four π cabinet and your analysis tends to confirm this as well.
If you want a great bang for the buck, pick up an Alpha 10 and put it in a 4-5ft3 box tuned to 35Hz. I expect you can get those even cheaper from the dealer near you. They're a great part - can be used for a midrange or a woofer.
Re: box [message #49846 is a reply to message #49844] Thu, 10 August 2006 14:55 Go to previous message
Thannks Wayne .
Previous Topic: Request for 7 pi plans
Next Topic: wirewound resistors
Current Time: Sun Nov 01 16:54:09 CST 2026
