Home » Sponsored » Pi Speakers » help with pi alignment
help with pi alignment [message #49827] Wed, 09 August 2006 10:20 Go to next message
Jim Dudley is currently offline  Jim Dudley
I'm looking for help with a Pi alignment for following car subwoofer. (I use this alignment with an Altec 515-8g at home and love it but someone else made the calc for me.)
Driver: Image Dynamics IDQ10 D2 V.2
Dual voice coil. Will series wire for 3.7 ohms Re
Fs 23 hz
Qes .345
Qms 4.77
Qts .322
Vas 2.26 cu ft
Sd 350 cm2
SPL 89.4
I would like to use a 2.5" dia port
The manufacturer has some recommendations but have no idea what alignments.
Thanks!!
Jim D.
Image Dynamics IDQ10 [message #49829 is a reply to message #49827] Wed, 09 August 2006 16:33 Go to previous messageGo to next message
The Image Dynamics IDQ10 woofer looks good in cabinets from 0.5ft3 to 1.5ft3 tuned to 26Hz. PiAlign suggests 0.75ft3 which provides a nice flat response curve that is slightly overdamped. It has f3 of 40Hz and f10 of 25Hz, so it will sound very nice in home or in a car. Being slightly overdamped, room/cabin gain will effectively conjugate its amplitude response. For subwoofer use, you can go a little larger, to 1.0ft3 or 1.25ft3. That will give f3 closer to 30Hz, but f10 is still around 25Hz. The larger 1.0ft3 cabinet makes a great alignment for use outdoors or in very large rooms, but may sound a little bit boomy in medium to small rooms or in your car.
Thanks Wayne!! (nt) [message #49831 is a reply to message #49829] Thu, 10 August 2006 04:58 Go to previous messageGo to next message
Port tuning frequency [message #49832 is a reply to message #49829] Thu, 10 August 2006 07:31 Go to previous messageGo to next message
Wayne,
One more question My enclosure looks like it will end up at 0.86 cu ft for the space I have, very close to the pi alignment volume. What frequency should I use for port tuning? I could reduce to .75 cu ft if it matters.
Jim D.
Re: Port tuning frequency [message #49835 is a reply to message #49832] Thu, 10 August 2006 08:51 Go to previous message
Tune the cabinet to 26Hz. The IDQ10 works well in cabinets from 0.5ft3 to 1.5ft3 tuned to 26Hz. If you made the cabinet larger than that, you might want to tune lower for an EBS alignment. But in the 0.5-1.5ft3 range, 26Hz is the best Helmholtz frequency for that woofer.
Previous Topic: news no mail
Next Topic: Request for 7 pi plans
Current Time: Sun Nov 01 16:54:13 CST 2026
