Home » Sponsored » Pi Speakers » Help a newbie! Please?
Help a newbie! Please? [message #49668] Sat, 24 June 2006 19:25 Go to previous message
Claudio Rocco is currently offline  Claudio Rocco
Hello speaker builders, thank you in advance for all the help you are willing to give.
I just purchased a pair of Two Pi Tower kits, and want to make the cabinet using 13/16" marine plywood with 1/2" natural wood around the inner plywood box, on all sides plus a plinth or base for the tower.
My questions are:
1.- What inner dimensions should I respect in a Two Pi Tower box? The plans detail only outside dimensions of 46"x16"x13".
2.- The thicker or stiffier the baffle, the larger the port hole must be? Why is that?
3.- The "General Tips" file says "Remember, you can’t overbrace!". Does that mean I should use as many braces as possible? Or does that mean only to use enough bracing as recommended in the plans?
Previous Topic: How-to
Next Topic: Active Crossover - 4Pi Tower?
Current Time: Tue Oct 20 13:49:04 CDT 2026
