Home » Sponsored » Pi Speakers » Pi7 can I do it DIY?
Pi7 can I do it DIY? [message #49635] Sun, 18 June 2006 13:55 Go to next message
Stefan I is currently offline  Stefan I
Hi Wayne,
I am currently contemplating building the Pi 7 audiophile or profesional speaker - I am unsure as to if I am currently capable of this project DIY- I have built a DIY reflex cabinet before.
What I want to know is - can I do it? Will I be able to understand the plans?
Best regards
Stefan
You've got mail! [message #49636 is a reply to message #49635] Sun, 18 June 2006 14:49 Go to previous messageGo to next message
Re: You've got mail! [message #49639 is a reply to message #49636] Mon, 19 June 2006 00:52 Go to previous messageGo to next message
Wayne,
Wow - that was quicker than quick - many thanks!
Now I have some study to do.
If I have any questions I will do as you suggest.
Many thanks
Stefan
Re: You've got mail! [message #49640 is a reply to message #49636] Mon, 19 June 2006 01:09 Go to previous messageGo to next message
Hi Wayne,
Could not resist looking through the plans / documents you sent - the documents labeled crossoover.jpg seems to be empty is this how it is supposed to be or is it just my computer?. The rest of the .jpg documents seemed Ok.
BTW it does not look that hard to build - but some more study first - followed by some action over the summer hols
Best regards
Stefan
Re: You've got mail! [message #49641 is a reply to message #49640] Mon, 19 June 2006 08:11 Go to previous messageGo to next message
The crossover is a GIF file, so check and see if your PC blocks GIF files for security purposes.
Re: You've got mail! [message #49642 is a reply to message #49641] Mon, 19 June 2006 08:22 Go to previous messageGo to next message
Hi Wayne,
The other Gid files came over Ok and had contents in - so not sure why this one was empty? Does it read Ok on your end?. If it is Ok perhaps if ou resend it the problem will go away.
Rgds
Stefan
Re: You've got mail! [message #49643 is a reply to message #49642] Mon, 19 June 2006 08:27 Go to previous message
All the other image files are JPG files, and the security settings treat those differently. I suspect that's probably the problem and that you can change settings to be able to view it. But I'll resend the plans just in case.
Previous Topic: Power Transfer into Professional Pi7
Next Topic: Frequency responce slope question
Current Time: Sun Nov 29 14:47:43 CST 2026
