Home » Sponsored » Pi Speakers » bass as per enclosure
bass as per enclosure [message #49614] Fri, 09 June 2006 08:17 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy Wayne . Could tell me Wayne as compare the 2pi bass to the 8 pi bass . what enclosure give more punch ..Thanks
Re: bass as per enclosure [message #49615 is a reply to message #49614] Fri, 09 June 2006 09:06 Go to previous messageGo to next message
Bass from the two π tower and the eight π loudspeaker is about the same. The biggest difference is in the midrange, as you might imagine. The eight π midrange is clearer and more defined and more uniform off-axis.
Re: bass as per enclosure [message #49619 is a reply to message #49615] Fri, 09 June 2006 18:08 Go to previous messageGo to next message
Thanks Wayne just a last thing . So that the 8 pi dont have front woofer radiation only back radation what range of frecuency handle the 3 square port I think that from 35 hz to 500 hz but you answer dissipate dudes . thanks again
Re: bass as per enclosure [message #49622 is a reply to message #49619] Sat, 10 June 2006 10:29 Go to previous message
That's a common misconception - bass doesn't come solely through the ports. Bass sound pressure comes from the front of the cone just as it does from the back. The rear wave is tuned by a Helmholtz resonator which loads the cone at bass frequencies, but most of the sound you hear comes from the front. Only a narrow range in the bottom octave comes through the ports.
Previous Topic: Testing for T/S
Next Topic: What's the difference between the 2Pi tower and studio???
Current Time: Fri Nov 06 21:32:32 CST 2026
