Home » Sponsored » Pi Speakers » Tower 2
Tower 2 [message #49587] Wed, 07 June 2006 09:53 Go to next message
schulzr is currently offline  schulzr
After finally finding some time, I've boughten the wood for making the T2's. I'm going with 13/16 Birch for the fronts, sides, and tops and 5/8 MDF for the bottems and rears.
Wayne...any additional suggestions...ie Port hole diameter, etc.?
Re: Tower 2 [message #49588 is a reply to message #49587] Wed, 07 June 2006 10:55 Go to previous messageGo to next message
Have I sent you the plans? They show the port size, which depends on wood thickness. Place cross-braces a third of the way up in the cabinet and a third of the way down. Span the cross-section with a sheet of acoustic insulation in addition to lining the inside top, front and side walls.
Re: Tower 2 [message #49590 is a reply to message #49588] Wed, 07 June 2006 11:55 Go to previous messageGo to next message
Yes you did and my detailed sketches are made from your plans. Is the 4 5/8" port size for the 3/4" close enough for the 13/16" thick board I'll be using? (Extrapolating would be 4 11/16" but I think I would be splitting hairs..or...?) BTW, if you'd like them for your review and use, I've got the sketches in Autocad.
Roland
Re: Tower 2 [message #49591 is a reply to message #49590] Wed, 07 June 2006 13:32 Go to previous messageGo to next message
Did you say the rear is 5/8" thick? If so, use a 4 1/2" diameter port. If the rear panel is 13/16" thick, then I'd go with 4 5/8".
Re: Tower 2 [message #49592 is a reply to message #49591] Wed, 07 June 2006 14:07 Go to previous messageGo to next message
Thanks Wayne...I snooped around the forum and found the answer about the same time you responded. (Should've looked before asking)....
Now I've got another q.......Do you glue the rear panel on permanently or do you secure it in another way? I understand the importance of a tight enclosure, but what about maintenance, repair, fine tuning, etc.....?
Re: Tower 2 [message #49593 is a reply to message #49592] Wed, 07 June 2006 14:17 Go to previous messageGo to next message
I glue them together. You can access the drivers easily enough for service. Nothing else really needs maintenance.
Re: Tower 2 [message #49594 is a reply to message #49592] Wed, 07 June 2006 14:35 Go to previous message
Roland,
You access the inside of your finished enclosure through the driver cut-out. If you plan on taking the driver on and off frequently, use t-nuts and bolts instead of woodscrews.
Gar.
Previous Topic: Value of JBL2205's?
Next Topic: Okay, so Wayne was right.
Current Time: Mon Nov 23 06:44:14 CST 2026
